Low temperature reading
napalm1432
Posted · Low temperature reading
Hello,
I'm having an issue with my heated bed, none of the thermistor settings seem to work right, except for one, only the temperature reading is about 20C to low, is there a way to fix this?
I can't find the specifications of my heated bed, but i measured the resistance and got about 100Ohms.
Hope anyone can help with this.
The only thing i do know of the heated bed is that it is a silicone rubber heated bed of 300x300mm 24V
I just can't find the resistor value..
EDIT:
Actually found a way around, changed some settings in thermistortables.h and now it's displaying the correct temperature
          • Confused
        • 6 replies
