Top layer missing/bad from print, what could cause this?
macua85
Posted · Top layer missing/bad from print, what could cause this?
Hey guys,
The top layer of models seems to be incomplete. As per below pic, in stepped models walls are fine, just the top layers. Any ideas?
http://umforum.ultimaker.com/index.php?/gallery/image/11762-top-infill-missing/
Sorry can't embed pic as on iPhone. Mods if this is in wrong section please can you move.
It's so frustrating, can't produce any prints properly, and have to scrap the ones above too now! Any help much appreciated.
Thanks
    Is it attempting to fill the top layers or is it just not printing the top layers?
    If it is the latter and if you sliced with Cura, make sure the top and bottom options are checked in Expert menu -> Open expert settings / Infill section / Solid infill top & solid infill bottom.
    Hi anon, It looks to be trying to fill in, but they were over night prints so didnt watch it. I'll check that out when I get home. Ill also post the gcode, someone might be able to see the error in that.
    Thanks for the reply
    1) Did you look at the part in Cura layer view first? Make sure cura thinks it is *supposed* to fill in the tops.
    There are lots of reasons why it might not fill in the top. But here's my second most likely reason:
    2) The photo sure looks like underextruded infill although the walls look okay. Do you:
    2a) ...have a different infill speed than shell speed?
    2b) What is your print speed, nozzle temperature and layer thickness? These 3 values combine in a curve such that if you are above the curve it will underextrude badly:
    http://umforum.ultimaker.com/index.php?/topic/4127-um2-extrusion-rates-revisited/
    Thanks fore reply gr5.
    1. The layer view in cura showed it as being there.
    2. the walls are perfect, i'll get a better photo tonight.
    2a. I do have infill set to 130%, but the infill was coming out fine, the missing layers are the top/shell.
    2b. Print speed was (i think but have to confirm on gcode), 80mm/s, 0.2 resolution, 212 nozzle temp.
    Taking a look at that graph, i'd expect to see underextruded infill, but its not. Its the slower layer that is (possibly) underextruded. Take with the the fact the walls are absolutely fine, its very odd. The top layer of the wall is also showing the same problem (although on much small scale).
    Are you sure it's only missing the top supposedly-solid layers? It's not just a clogged nozzle for any reason that happened close to the top of the part?
    It's not very clear from your first post, does it happen on every piece now but used to work before? Or just on this part?
    Yea its two parts its happened on now. the walls were printed after the main piece, and they came out fine so struggling with the concept of a blocked nozzle. Will atomic it just incase though.
    I also printed some nano props yesterday, and had no such problems. However these don't really have a 'top' to them, so maybe thats why the problem didn't manifest itself with those.
    Oh right, didn't notice at first that some walls were going higher than some internediary "top" surfaces.
    Have you checked what anon4321 said? the solid infill top was checked in your expert settings? It should, if you say that it is visible in the layer view, but just to be sure.
    Your printer is a modified/copycat UMO?
    Its a UMO with HBK (but thats broken) and dual extruders.
    genuine....i might be in China, but i'm western and buy real stuff!
    well you would have got a faster after-sales service :-p
    out of curiosity, did you import it, or just took in your luggage?
    I relocated from Singapore, so I had it shipped to there in the kit, then moved to china so it got shipped with all out stuff here...then I built it! I won't talk about after-sales in here, i'm going to give them a little more time...
    212C, .2mm layer, .4mm nozzle, 80mm/sec is beyond what a UMO can do for most PLA. You need more like 230C. I know you say the walls are perfect but 10% underextruded walls will typically still look great. The filament is almost surely slipping quite a bit.
    Your problem *might* not be undrextrusion but this is the easiest thing to check. Keep your print speeds well below the dark blue line in the graph I linked to above. So for example either reprint but at 240C or slow it down to 40mm/sec.
    I believe top infill prints at the same speed as infill. I'm not sure what 130% means as in the recent versions of Cura (last few years) it only allows you to set the speed in mm/sec (advanced tab, speed). There used to be an old print window in Cura where you could set the infill speed % higher. Are you using that? At any rate, keep the infill speed also below the values I mentioned (80mm/sec at 240C or 40mm/sec at 212C).
    By the way it's very common for heavy underextrusion to suddenly stop printing. I don't know why exactly. One theory is that the feeder is grinding/slipping the filament but this isn't always true. Another is some kind of temporary clog but when I start printing again it's always fine. So I'm trying to say all 3 of your symptoms (printing too fast/cold, underextruded infill in the photo - yes that's exactly what it looks like, and suddenly it stops printing) point to the same thing.
    I don't truly understand it. Here's a nice photo that shows print speed and underextrusion (severe) and you can see where it also stopped printing near the top of the part (post #2 - purple cube):
    http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
    Well...turns out I'm a noob idiot! I thought infill speed was a % multiplier of print speed, didn't realise it's a mm/s setting! I had it set to 130!! So gr5, you were absolutely right, and about top layer being done at same speed as infill. Thanks for the help guys, sorry for my retardedness!
