Limit blocks sagging
luke-dann
Posted · Limit blocks sagging
Hey guys and girls.
Just finished building my Ultimaker Original Plus and I was running the calibration.
The print head moved all the way to the left and made a terrible juddering noise. Naturally I investigated and I saw that the limit block LEFT sags forward from the weight of the emitter and it's little wooden tag on the back misses the limit switch.
I've got the switch all the way over as far as it will go but it only seems to hit the switch when the block is level, not when it's sagging.
Any bright ideas?
