A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
IRobertI 517
There's quite a bit of info in this thread: http://umforum.ultimaker.com/index.php?/topic/4380-how-to-square-axis-in-assembly-solved/
It also showed an uncommon problem where the head of the printer was not square.
Besides the squareness of the rods you might check:
- Lubrication. The axes likes a single drop of a light machine oil such as sewing machine oil.
- that no belts are rubbing against the side of the machine.
- that the the end caps for the rods aren't causing too much friction
- that the rods haven't become bent
There's probably other stuff to check but that's what I can think of at the moment.
