Getting close to that release... 15.01-RC11
Daid
Posted · Getting close to that release... 15.01-RC11
ALERT @ DAID!!!
Please correct the version information at the "software" page on Ultimaker.com - there is already 14.12.1 mentioned !!!
I checked just this so overseen the release of 15.01. up to now.... :-(
    ALERT @ DAID!!!
    I checked just this so overseen the release of 15.01. up to now.... :sad:
    Just give us a few days to roll this out to all areas. Not everything is automated yet on the new website. So some things need manual updates. There is also no update notification yet for this same reason.
    Never seen that happening before (naturally, I tested the 15.01 release on Windows7 a few days before the actual release)
    The lack of printing time info most likely means that the engine isn't starting properly.
    Can you post the contents of:
    C:\Users\[username]\.cura\15.01\output_log.txt
    That might give a hint in what is going wrong.
    I too have this problem. I run WIN 8.1. I must be noob since i cant find where to upload that txt file. but ill copy a part of it here:
    # Generating comtypes.gen._683BF642_E9CA_4124_BE43_67065B2FA653_0_1_0
    # Generating comtypes.gen.TaskbarLib
    Loading old settings from C:\Users\Marko\.cura\14.12.1
    Failed to listen on port: 49674
    Listening for engine communications on 49675
    Flashing 118826 bytes
    Verifying 118826 bytes
    Running: C:\Program Files (x86)\Cura_15.01\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode= -s supportXYDistance=700 -s insetXSpeed=50 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s gcodeFlavor=1 -s postSwitchExtruderCode= -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=50 -s coolHeadLift=0 -s extrusionWidth=400 -s upSkinCount=6 -s initialLayerSpeed=20 -s minimalLayerTime=5 -s infillSpeed=50 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=2850 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=18000 -s extruderOffset[1].Y=0 -s layerThickness=100 -s endCode=M25 ;Stop reading from this point on.
    ;CURA_PROFILE_STRING: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
    -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=4500 -s skinSpeed=50 -s skirtLineCount=1 -s startCode= -s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=150 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2000 -s insetCount=2 -s downSkinCount=6 -s multiVolumeOverlap=150 -g 49675 -s posx=117944 -s posy=146155 $
    Cura_SteamEngine version 15.01
    Copyright © 2014 David Braam
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU Affero General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU Affero General Public License for more details.
    You should have received a copy of the GNU Affero General Public License
    along with this program. If not, see <
    Default config 'default.cfg' not used
    Reading mesh from socket with 67224 vertexes
    Loaded from disk in 0.031s
    Analyzing and optimizing model...
    Face counts: 22408 -> 21542 96.1%
    Vertex counts: 67224 -> 10501 15.6%
    Size: 56.782000 52.947000 80.000000
    vMin: 89.553000 119.682000 0.000000
    vMax: 146.335000 172.629000 80.000000
    vMin: -25.447000 7.181000 0.000000
    vMax: 31.335000 60.128000 80.000000
    Matrix: 1.000000 0.000000 0.000000
    Matrix: 0.000000 1.000000 0.000000
    Matrix: 0.000000 0.000000 1.000000
    Optimize model 0.047s
    Slicing model...
    Layer count: 798
    Sliced model in 0.344s
    Generating support map...
    Generating layer parts...
    Generated layer parts in 0.140s
    Generated inset in 0.719s
    Generated up/down skin in 1.266s
    -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s skirtMinLength=150000 -s objectSink=0 -s retractionAmount=4500 -s skinSpeed=50 -s skirtLineCount=1 -s startCode= -s skirtDistance=3000 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=150 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2000 -s insetCount=2 -s downSkinCount=6 -s multiVolumeOverlap=150 -g 49675 -s posx=120415 -s posy=152975 $
    That's odd, everything looks normal there.
    Got any firewall software running?
    Also this line:
    "Failed to listen on port: 49674"
    Hints at that there is still another copy of Cura running. (Cura uses a local socket on port 49674 to communicate between the engine and GUI. However, if it fails to use that port it will use the next one)
    I'm not sure if the version I am using right now is the latest and most current one but Cura 15.01-RC11 works pretty well for me. I only encountered the following problems, maybe they have already been solved in a newer/more current version but I thought I'd write them down anyway:
    1. The printer does not perceive gcodes with "ß" in them. The problem existed before with Umlauts (ä,ö,ü) and I think it has been solved in the recent version. However the letter "scharfes S" (ß) causes the same problems.
    2. Although I have the possibilty to save the different profile-settings on the SD-card there were no files including the settings on the SD-card whenever I tried to save the profiles. Maybe I just did something wrong though.
    3. Maybe this was a Cura 14.12.1 problem but I'm not completely sure so I thought I'd adress it here as well. It looked like the first line of the brim was printed slightly besides the second line of the brim. For round objects like rings and cylinders this would cause ugly lines in the the bottom surface because the first brim line would be where the actual part would be printed and the different lines overlapped and were printed above. This was a problem especially for cylindrical objects and rings.
    Other than that I like the new 15.01 and the new firmware. I really like the new quick-access to the expert settings as it gives me the option to change the number of brim-lines very fast and easy. The idea of saving and exporting settings to the SD-card is great as well!
    Regards
