DidierKlein 729
Also check your minimal layer time if you set it to 0 it won't slow down on smaller parts
I think you are talking about the minimum layer time. Default is 5sec. So If your layer is very short, Cura will slow down the speed to assure the next layer is not lay down too fast (5sec)
Thanks for the quick and firm answer. Yes, the minimum layer time was set to 5sec. When i repeat the tests i will confirm the result.
I think the acceleration was not the problem, as long as the "faster" area was "H" shaped while the slower one war a rectangle (same size, smaller primeter).
nallath 1,117
Just because you tell it to go at a certain speed, it does not mean it's able to get there. The printer has an acceleration setting, so if the segment it's printing isn't long enough, it won't reach the speed (as it also needs time to de-accelerate).
Don't be fooled by claims about speeds that a printer can reach. In most cases it won't ever reach them due to these constraints.
