cloakfiend
Acetone Finishing on PLA
Posted · Acetone Finishing on PLA
I did notice that because of the hat on the model, the layer lines where much better than normal on the freddie models face due to it being shielded with support material, which indicates a wall around the object might beneficial in surface quality. both models were printed with identical settings one day apart.
Share this post
Posted (edited) · Acetone Finishing on PLA
These photos show the effect of acetone on a part that I left on purpose in acetone for way too long (more than an hour), just to try what would happen. It got weak, lost its spring-effect, and cracked. Its strenght recovered somewhat in the next months when drying, but not fully. Now I broke it.
So you can see how deep the acetone penetrated and cracked the model. The inside seems to be still chemically affected, as it broke in a weird way, with very different inner and outer fracture surfaces. This is yellow PLA/PHA from colorFabb. The fracture surface is ca. 6mm x 4mm.
Edited by geert_2
Share this post
Yes indeed. Acetone goes deep. Deeper than Eddie Murphy going undercover in Bevery Hills Cop.
It can also shrink. A lot! Ive done many tests on this. Its why you need to be very careful with exposure times and why brushing is less prone to warping than dipping which can play havok with hollow models.
Share this post
Another thing is fire places and sources of intense heat or constant heat will affect the models a lot. The acetone tends to dry them out and intense heat even further causing rapid splitting. Also heating up a closed hollow model after acetonig can cause the model to inflate as acetone reaction seals the model from moisture... once you know how it reacts you can pre determine how to do things.
Share this post
    • January 22nd  | Ultimaker webinar 'Learn how to choose the right composite material'
      We’ll teach you how to choose the right composite material for your application in our new 40-minute webinar. You will learn how to:
      • Make the perfect choice between glass and carbon fiber
      • Identify more high-value applications that would benefit from composites
      • 3D print advanced materials with the right settings
      • Select the best materials for 3D printing end-use parts
      • Use dual extrusion to take composite 3D printing to the next level
    • Does your company use Ultimaker? Know one that does? Let us know!
      If your company uses Ultimaker in any capacity, we'd love to hear about it! If the story is there, and you're up for it, maybe we can work together to create a story that will be featured on the site. Here are examples of..
Important Information
Welcome to the Ultimaker Community of 3D printing experts. Visit the following links to read more about our Terms of Use or our Privacy Policy. Thank you!
