Do you use zhop? it could cause more wobble
No haven't used that I don' think....will check tonight though and report back. Is it a plugin or a selectable option?
The um does not like the cold, loads of nozzle jams, i had it in a server rack full of fans and it was a disaster.is best you don't even breath on it when its printing. Just let it be. I always print at pla 210 35 mm at 0.06 now. Used to do 70mm at 230 but no more. Having a real bad time recently. Someone has messed about with the printer i can tell some fan holders are bent and the filament is incorrectly loaded, and nozzle is blocked. Well annoyed, wanted to do a tutorial this weekend, but doesn't look like thats gonna happen.
visu-al 2
thats why i would prefer slow movement espacially if it gets thin and tall
