The plugin runs before you save the file. Therefore it cannot know the final filename. The only thing it can know is the name of the temporary file created by Cura and handed over to the plugin.
But the filename is created by the model you load, this model has a name and when you save it it becomes (modelname.gcode). And the model is loaded before the Plugin.
Isn't there a way to get this name?
Dim3nsioneer 559
