I didn't change any settings in the expert settings, so it should be the default. I'll double check when I get home though.
I confirmed that the retract settings are the default 1.5mm.
Do you have combing disabled? If so, then this is expected behavior. (Sorry, should have thought of that first)
The change of infill order is intentional in 15.01, it has to do with the new infill&top/bottom skin speed. This order simply gives the best looking results if you print the infill at higher speeds.
Daid 304
What's your minimal travel between retractions set on? (expert setting, default is 1.5mm)
