where I find my printer setting (MAC)
markus-reinisch
Posted · where I find my printer setting (MAC)
Everytime Cura gets an update the settings for all my printers are gone.
Not the slicer setting, the settings for the printer.
I got 3 printer profiles for different printers, and these are gone. Only one UM original is left.
Where can I find them? So that I can copy from my Time Machine Backup this settings. I don't want to make new printers and make new settings for those.
    I see some machine profiles if you right click on the cura app (MAC) and choose show package contents. Also I see that you can save the profiles from the main menu bar. Best to have a backup copy of those saved. So at worst you could just restore cura from Time Machine, open it up and save your profiles.
    Ya I guess the profiles save option is probably for slicing and not for the machines.
    [home]/Library/Application Support/Cura/
    thanks found it.
    Why cura copys the file to the new version?
    They are in folders for the cura versions.
    nothing there, no Cura folder.
    in the hidden folder: ~/.Cura are all the versions up to 14.06-RC6 although I have almost every release after that.
    How to reorganize this? Should I delete folders? Move them?
    Plug ins Folder is in the hidden folder as well.
    'Load profile from gcode' always returns with the error: 'No profile found, only works with versions by Cura 12.07 or newer'.
    have you take a look in (user) and then /Library/Application Support/Cura/
    Aparently since Cura 2.1.x it's somewhere else.
    Any idea?
    It's only publicly documented where they store the printer profiles on Windos.
    I found the location of the Printer's Profiles for Mac.
    Users > 'YourUserName' >Library > Application Support > cura > 'current # version of cura' > cache > definitions > 'current # version of cura'
