Just left this same tip in another thread.
I clean around my hot end and aluminum fan shroud using a Dremel with wire brush tip on the lowest speed setting. Works beautifully and leaves the metal looking brand new. I too had a failed print go on for about 8 hours, coating everything from the hot end up in molten plastic. Took about 10 - 20 min to clean it all up.
Stay away from the bottom of your hot end with the Dremel. You don't want to reshape it by accident and ruin your prints!!
gr5 1,872
The isolator is the white part - it's teflon. Don't heat it above 250C (don't use a torch on it). Maybe you mean the "isolator nut"?
You can burn out any remaining PLA or you can just turn on the nozzle heater to 150C and when temp is stable screw the nut on. Try not to burn yourself (use gloves and/or tools).
