15.0.1 problem with printing on my ultimaker original
markus-reinisch
Posted · 15.0.1 problem with printing on my ultimaker original
I tested the new version and there is a problem with moving the printhead slow. Then my printhead begans to stutter and you can put the print in the trash.
I've upgraded the firmware but I only use 115000 because with 250000 in speed seting for communication I can't use my printer with octoprint.
    I don't know about 15.01, I am still on 14.07 :rolleyes: but
    • UMO firmware has not really changed recently, so your problem is not coming from there
    • I am not sure to understand why you need the 115200 firmware, as it is mainly there for historical reason. Octoprint should just work fine with the 250000 firmware (mine does)
    with 250000 I could not connect with raspi when it set to 250000, with 115200 no problem.
    I use for my fair phone cases 14.07 cause it slices better, for normal things 14.12. I want to test 15.01. But when the printer doesn't work properly it's useless.
