printing time very different on 15.01
stonemonkee
Posted · printing time very different on 15.01
hi,
I loaded the same profile and model on both version 15.01 and 14.07.
The estimated print time on 14.07 is 3hrs 10 mins
and on 15.01 its 6 hrs 8 mins !!!
I have checked the expert settings also and they are also the same.
Any ideas whats causing this??
    layer height is different. It makes hell of a difference :)
    Edit: shell thickness too but that will cause less changes. By the way you should try keeping the shell thickness to a multiplier of the nozzle size. If the nozzle is 0.4mm use 0.4, 0.8, 1.2,... for shell
