I had a quick look at misumi already but found the options a bit overwelming
Very true. TBH, I didn't do any calculations, to some extent it's a shot in the dark. Just went for the long blocks for less play. An axis with two parallel rails should always be fine. With the one rail axis, I'll have to see. And for the other options: I tried to choose the cheapest ...
When I looked at rail systems for my CNC many years ago, my impression was that one really needs a pair to avoid any significant wiggle. It just doesn't take much angular freedom at the rail to cause problems, when the tool extends out several cm. Perhaps designing the tool holder to keep the hot end as close to the axis as possible would help, but than your center of mass (and/or Bowden) will be way off axis and able to apply a substantial torque.
A lightweight second rail could be added opposite the tool changer to help reduce the degrees of freedom. This would be like the very small bearing used at end of the non-load bearing side of a rotating shaft, in order to offset the load. In thise case, the rail could be oriented to maximize its vertical rigidity.
neotko 1,415
Lol XD indeed
