Ultimaker Community of 3D Printing Experts
A different multi-extrusion approach - UM tool / printhead changer
  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Posted · A different multi-extrusion approach - UM tool / printhead changer
Yea that would be the best approach for sure, but would require a more complex arrangement of the main carriage. Any which way the print area is going to be reduced quite a bit though..
    I use Moi3D.
    The plan is for it to be able to pick up a print head from either corner, correct? Seems like that would make the most efficient use of space.
    Yes, a simple, single-sided gripper would be easier but I can only think of designs here which occupy a considerable part of the print area.
    Hmm, can it export or convert to .ipt files? I use autodesk inventor. I can start from scratch too though if needed.
    sorry, no .ipt.
    IGES, 3DS?
    Just read somewhere that autodesk inventor may be able to open .3dm (openNURBS) directly?
    Uploaded sample files for a 30x35mm mount (30x30mm cartridge, 35mm high).
    Cut out the magnets of you choice (2 x approx 1.5 kg holding force is fine) and incorporate the mounting plates into your design.
    I was thinking that from the top the design would look like a capital "T". The top of the "T" would be just wide enough for the bearing and the vertical part would carry the magnets with alignments points for the cartridge on both sides. Ideally it would be just thick enough to accommodate the y axis bearing. The print head would be oriented to keep the hit end as close to the x axis center of the holder.
    My assumption, based on the current design, is that the print area lost due to the offset between the hot end tips would be less than the area lost due to the unusuable gap between the hot end docks (when they are placed on the same side.) But that is just a guess and might not be true, if the are required for accessing the dock is made small enough.
    Also thinking that the direct drive extruder mechanics could be mounted high enough that their bulk might fit over the xy carriage. Then the hot end would fit down through the corner, so that the cartridge would have a profile of a block on top with a rectangular block coming down from one corner.
    Almost exactly my thoughts... The "T" with mirrored cartridges is my first choice for a dual setup.
    If standard electronics would allow for more a quad setup with "X" shaped gripper and identical cartridges and holders in each corner but rotated by 90/180/270° would be interesting.
    And yes, you can put the bulk above the gripper. The only thing to bear in mind is that there is not too much inert mass or a long lever where a force can attack to break the holding force of the magnets. But the 80 gr of the NEMA8 were no problem at all.
    I've just ordered a couple of E3D v6 hot ends for this project. I like my dual extrusion, so considering the dual carriage setup straight off the bat. I also ordered the bowden version to try first, as I think this will allow for an extra small carriage. Also waiting to hear from Mutley3D. Ultimate aim is definitely flex drive.
    Am am able to load the Stp files into inventor. Do you happen to have the 'phmod v5 head' file in the same format?
    Apologies, didn't realise you had already sorted the dual carriage part with the 'module'which appears to allow carriages on both the left and right side of it (looking from top down from the front). I've managed to modify the file to suit the magnets I have got, hopefully they are not too strong being the 3mm ones. Printing now in clear XT.
    50% more holding force should be ok because the split/unlock move doesn't require much force.
    Did you print the corner split tool in two parts of one? In the STL its one part, but when I open the stp, I can see its designed in two parts.
    Btw, printed the other parts, and its a great printing design, so easy. The XT came out really well. I read you have been having problems with it, and I have also. However with 100% infill, 247 nozzle, 70 bed and 0.1 layer height with 50% fan it worked well. Oh and 40mm/s speed.
    I'm also going to have a go at other designs, try and make it more compact with less space loss. It seems the left hand side of the build area is out of use, might limit printer function considerably, especially for larger prints.
    So, this may be an idea. I know it means you may lose build height, but maybe the lesser of two evils. Especially with machines like the UM2 extended coming out. Also, the E3d is only 60 something mm tall, so don't think it will end up far off the standard UMO height. Tool storage and collection may render the some of the build plate unusable on the right hand side though, not thought too much about that yet.
    https://www.youmagine.com/designs/module-underslung-tool-carriage
    PS its only a very crude model of it to see what it would look like. A E3D bowden setup I think would be possible with this design, but the direct drive carriage maybe not without compromising too much height.
    Also just realised with a design like this, only single sided is required, and both tool carriages could be stored at the back left and right of the machine, where the least space is wasted as the heated bed doesn't go back that far. This would be a kind of Asymmetric design. Just have to design the carriages for the bowden and wires to miss the gantry. Apologies for the rambling, just getting my thoughts down.
    Very crude remodel based on above thoughts:
    Magnets arrived today, so will start the redesign in ernest. Ive started to design the tool carriage home for the back left of the UM, with a view to mirroring it in Cura for the back right side. I'm hoping for no more than a 30x30 carriage with the E3d V6 and bowden setup.
    If anyone wants to try it: https://www.youmagine.com/designs/e3d-v6-modular-print-carriage-system
    Edit: just printed, but not quite right yet. Youmagine description has details.
    Any way this could be done with a tool head revolver? It seems a shame to loose more print area with each added head.
    As long as its only 2 heads, print area is not reduced by much. But its a good idea, anything is possible given the time and inclination!
    Including commands to control the head revolver into the gcode may also be problematic, not sure how that would be done.
    Well, CNC machines do tool changes with ATC revolvers all the time, but I figure that the simplest way to control a revolver from the gcode in Marlin would be to treat the revolver as the first extruder, and the true extruders as extruder 2, 3, 4, .... Then, you could issue a M302 P1 (allow cold extrudes, necessary since the revolver is "cold"), then a T0 (select the revolver), then rotate the revolver to drop the old head and pick up the new head, then issue a M302 P0 (deny cold extrudes), and a T(?) to activate the newly selected head. This all presupposes replacement electronics that support multiple extruders, but you would need that past dual extrusion anyway.
    Interesting idea. I'll try to get this working with the current proposed setup first I think. The main aim for me is clean dual extrusion prints. After that direct extrusion by flex drive so I can print ninjaflex etc.
    One difficulty I see is keeping all the filament tubes from getting tangled.
      • Startups, apply for the Forward AM Innovation Award!
        Are you a startup using 3D printing? Perhaps you should continue reading...
        Together with BASF we are launching the Forward AM Innovation Award - the very first global contest for startups developing new applications with 3D printing!
        Why apply?
        The winning startup will receive €100,000 in goods and services*, along with coaching and marketing exposure from top-notch leaders in the industry.
        Who can apply?
        Your startup creates products using Additive Manufacturing, is less than 5 years old, and has less than 50 employees. We are looking for 3D printing applications with a strong focus on innovation, sustainability and scalability.
        Dental aligners, shoes, tools, automotive parts, music instruments, industrial tooling and molding, medical implants, sports equipment, toys, architecture, fashion, construction... all are welcome to join!
        Do you have an innovative, sustainable and scalable idea that leverages the unique possibilities of 3D printing? Then it is time to apply!
        More information can be found here.
        Applications close on March 28th, 2021
        * What does "in goods and services" mean?
        The winner will be able to pick any item from the overall product and service portfolio of the sponsors, e.g. printers, materials, consulting, software... Choose whatever you need to accelerate your startup.
      • New here? Register your Ultimaker for free 3D printer onboarding course
