@foehnsturm does the changer firmware support a +feeder and an old feeder combination already? Or do we need to set e-steps every change?
foehnsturm 967
Afaik a gcode for setting e-steps would be required with every tool change at the moment. But I pass this to @Tinkergnome
I agree, using a different, probably already existing feeder is a nice option especially for tinkerers. However, professional users will most likely want to run identical drive trains.
I was thinking of people using there old head and feeder after the + upgrade.....
2
foehnsturm 967
That's what I had in mind as well.
The only think that worries me about 2 esteps it's that Marlin has a bug (at least on all umo/umo+) that was never fixed. And it kicks in as soon you change esteps and move the motor.
https://ultimaker.com/en/community/19301-calibration-error-marlin-ultimaker-original-plus
Basically everytime you change the esteps the first next move of the feeder will be absolutely 'nuts'. Also @Dim3nsioneer saw this bug in person
Dim3nsioneer 551
Yes and I still should report that... :(
Edited by Guest-
1
foehnsturm 967
Ok, don't want to put too much stress on Tinkergnome. (But he should be well rested anyway )
1
zerspaner_gerd 342
Hello,
can you describe me times the error.
I Prints with 2 different feeders and change the e-steps with M92.
A section of my change of nozzle:
M109 S240 T0 ;Druck TempT0 ; New ToolM92 E369.000 ;E-Steps T0 TOOL 0 neue FeederG92 E-20.000G1 E-4.5 F2400G1 X148.800 Y169.700 Z0.350 F3000G1 E0.000 F1500
thanks
so I understand you've never seen an error?Hello,
thanks
zerspaner_gerd 342
tinkergnome 917
I print only two weeks Dual, could see no error. What should I look?
It's only a suspicion a.t.m., but i think the M92 confuses the planner and a subsequent G92 is the correct 'workaround'. Good work!
foehnsturm 967
30mm/s on a race nozzle???
foehnsturm 967
Well, most people fail completely to print the super-soft FilaFlex with the bowden setup.
I'm sure I could go considerably faster but I want to keep temperature as low as possible cause dual extrusion needs working retraction.
Yes it's a very good result.
It just sounds funny to be using a race nozzle at 30mm/s.
foehnsturm 967
That's true
Btw where are you atm, Berlin?
In Amsterdam ready for my flight home tomorrow
foehnsturm 967
Oh, how time flies. Have a save trip home.
1
foehnsturm 967
Good call! Might be the same issue with Cura.
neotko 1,417
Wow quite clean for something that thin! I might put that polymax stuff on my shopping list. Also that flexible that @DidierKlein linked looks very sexy for the colors and specially because it's eco-friendly (and goes up to 102C).
