Hi Ultiarjan,
I saw your project on two different head it was quite awesum, i am using the mark2 kit, i just wanted to know how did u change the firmware or cura for picking up the first tool, cause i cud see a code for picking up the 2nd in the mark2 project,But there is nuthing for the first head, if its not a problem could you share this, as i was thinking of converting My mark2 to your configuration i feel this would really clear up the oozing issue when the first head is carrying the second, i await your reply eagerly on this, thanking you
Warm regards
Rajil Pahuja
foehnsturm 967
New forum topic started: Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade.
Let's continue the discussion there.
SandervG 1,419
Is everyone aware that there is also an amazing community contest going on where you can win a full Mark 2 upgrade, including an extrusion upgrade?
Definitely worth checking out!
