Posted · Under extrusion? Help me out please
Hey, this is my 8th print and 1st day of ownership of my printer. I have had great success with smaller objects at .01mm, but had some problems. How can I fix these problems?
Pictures below
Print speed 50mm/s
Layer height .25mm
PLA
230c
    I'm not seeing the classic signs of severe underextrusion. Are you refererring to the fact that the wall is not well bonded to the infill and top layer? I would guess that's probably due to the outer shell cooling down before it gets around to adding the infill. It could also be due to your very thin wall curling away from the body.
    I can think of a number of tweaks that might help. "Infill overlap" as suggested by Dodgrr might certainly do the trick. Or, raising the filament temperature a bit, increasing the shell thickness way more than what you have (I like 1.2mm when I want a high quality print), reduce layer thickness to 0.1. Some might suggest playing with the fan, but I'd be wary of that.
    In fact I'd do all of the above.
    Also I find gray tends to be the most likely to underextrude of the colors I have tried from UM. Plus .25 is a pretty large layer height, so I would try decreasing the layer height for your next print. Specially with gray.
    I tried the same print at .01mm and got massive under extrusion.
    Why does this part (same settings as the part above) look so great? Size?
    very weird.. kinda looks like a "material availability" issue, maybe crank up your print head temp a few degrees, could try tighting the feeder tension a bit too after making sure no plastic bits are cought in the teeth of the knurled wheel. impressive note-taking btw!
    You keep saying a layer thickness of .01mm, but you mean .1mm right?
    Yeah not .01, but .1. Sorry about that
    Problem solved. Solution: Switched to Robert's feeder, and used a spool holder with less friction.
    Well done. One tip: the clip on part on Robert's feeder is really only needed as support for flexible filament. For PLA etc I prefer to remove that so I can see the filament better, blow that area clean etc.
