Cura 15.01 plugin and save as on sd
carinac
Posted · Cura 15.01 plugin and save as on sd
After selecting plugin, this plugin can not be removed at Cura 15.01
Only a reset worked.
Save as toolpath is not directly sd card,but last opened folder
Both quite irritating issues.
For me it would be nice if I could export the gcode to stl from cura. Then I can change the support in sketchup f.e. and then reload it.
    Do you see the X button on the top right corner of the plugin? If not then you need to stretch the size of the panel a bit.
    So you have your sd card connected but it doesn't show you the save to sd card icon? Go in File->Preferences and make sure the Auto detect sd card is checked.
    The sd card icon is there but nothing happen when you click on it? Go in File->Preferences remove the "base folder to replicate on sd card"
    • 3 weeks later...
    Indeed stretching the panel helped, and I changed the directory in the preferences, thanks.
    About the sd card, in the UM the control panel used to show the last added file first, now I have to find it somewhere down, but not the last. Anyone knows how to change this?
    Thanks,
        • 6 replies
