Conductive Filament (ESD)
visu-al
  • 3 weeks later...
Posted · Conductive Filament (ESD)
That seems strange, unless your "leitbahn" originally was only 1 pass at 0.1mm.
Could you bring it further by increasing layer height?
Do several layers combine electrically?
    No, it is a bigger part and it doesn't really matter where i attach the measuring tip..
    The last Olson block i ordered, is for this machine to go and try 0.8mm wide and 0.5mm hight ;)
    Yes it combines well as i tested different layers/heights connecting in the print, i will test top to bottom and same line next time and write it down to have a better answer :cool:
    i try to imagine how this works that layer height effects the conductivity so much but no luck so far :mad:
    For people who wants to print this conductive pet:
    Switch off Combing!
    It makes a lot of drops and chunks around the print and..
    ..without it just prints very well @ 250-260° on kapton tape and 75°C bed , fan <50%
    Hi Visu-al,
    In my understanding, it is possible to use the ESD filament but its hard to control it, so, do you recommend to use it or not?
    Hi, How was the surface finish on these fillers? =)
    Magne,
    Norway.
