You don't need to clean your glass. The glue stick helps a lot with sticking. You need very little - if you want to improve the glue stick you can add some water and spread it around with a wet tissue such that there is almost no glue left - it should dry completely transparent but you can tell it's there if you scratch it with a finger nail.
Also Brim is very helpful in holding down large objects that are curling at the corners.
gr5 2,097
The gray PLA is fine. Print it at 220C with bed at 50C. Hotter won't make it stick any more. 30C or colder and it won't stick very well. At 70C (and 60C) the bottom few layers don't come out as well.
You're problem is most likely (85%) the leveling. I know you leveled 4 times. So stop leveling with the procedure. Now do it by turning the screws. Start your print and look at the brim or skirt as it is laid down. If it's so thin it's almost invisible your nozzle is too close (not likely). If it's roundish the nozzle is too far from the glass (this is most likely in your case). You want it squished somewhat flat like a pancake as the skirt is being laid down (or brim). For brim you want the lines touching - no gaps between. If there is a gap you need to move nozzle closer to glass. If there it's so thin it's almost transparent - too close. If the feeder is skipping backwards because it can't get any filament out you are probably also too close. Push down on the bed for a sec to increase the gap and see if the PLA spurts out.
If you are still having trouble please post a video of the first layer skirt being laid down. between 5 seconds and 30 seconds is all we need to see - more than 30 seconds is a waste of your time and our time.
