The best way to fix this in Cura is to add a third perimiter so the inner diagonal edge doesn't mess up the outside beauty.
The problem is you have top/bottom turned on (as you should) and so it thinks of this diagonal "top" of your print has having a top and it wants to make sure it is complying with the top/bottom thickness setting. I suppose another "fix" is to set top/bottom thickness to just one layer height (.15 in this case) but that might cause other ugliness. Playing with these 2 settings (adding a perimeter or reducing top/bottom thickness) should help you.
But the basic answer is "no you can't turn on this extra infill near edges".
gr5 2,334
