I printed two or three models without any problems after upgrading the firmware, on the next model it happened twice. its the heater error. im using the new fan shroud for more days and did not had any problems. I dont know did the downgrading firmware helped me or turning down the fan speed because i did both at same time. on the 2-10 layer i lowered the fan to 60-70% and the model printed well. Im woried about the sensors and the heater and i would like to follow the new firmwares too. i will maybe try to renew the firmware again, as i saw there is 15.02 out... and then il check the situation.
Can you tell me when you see on the picture is the heater/sensor enough in the block?
Thanks
gr5 1,516
Did the problem occur recently after upgrading firmware? Or recently changing fan shroud?
There's 2 distinct errors - one is something like "temp sensor" and the other one "heater error". The "heater error" message means the nozzle did not heat up the desired amount in the desired number of seconds.
The crazy thing is the feature was more likely to fail in 14.12.1. It had tighter limits then and has been loosened since then:
So as you can see version 15.01 is much looser. You might want to go back to 14.09.
