Just put a piece of cardboard on the surface then it will heat up faster, an no the cardbord will not start to burn !
Chri
Chri
Print at 100C, instead of 110C.
Had exactly the same problem, solved by the kind advise of Chrii. As he stated above - put a piece of cardboard on the glass, this will do the trick.
You could also get something for insulating underneath your HB... Like: http://reprap.me/heatbed/iso200.html
It might give you the last few degrees... Or at least make you reach 100 degrees a bit faster
Thanks, guys!
gr5 2,099
That's about right. I have UMO with heated bed kit (and UM2) and did a test once on the UMO heated bed which is identical hardware. Also I did a print last week and getting from 100C to 110C seemed impossible - I think the room was too cold or too windy or something as it actually dropped a bit I think so printed at 105C instead.
So for me it took almost 11 minutes to reach 100C and never really got to 110C unless I put a box over the top and plastic over the front.
