Thank you. That makes sense.
I split the object to print and am trying to print it standing up.
Again, just want to make sure if there is anyway I can add custom supports in Cura? If not I might just have to do it through my modeling software.
Have you read any problems in printing after latest firmware 15.02.1 was updated recently?
Best
Small
IRobertI 502
This is a pretty damn difficult print, just so you know. Increasing the density of the support might help a bit but the bottom side will never look as good as the top side.
I like to compare it to painting. Imagine painting a piece of wood and then set it down on something like the metal grid of a bbq. Let the paint dry and then pull the painted piece off, what will the bottom surface look like? Using support while printing is basically the same thing.
If it was my own model I would probably create a lot of custom support and print it standing.
