Dim3nsioneer 556
It depends...
...on how the plugin is written. Most plugins which are triggered on a certain height or layer number usually take effect at the start of a layer, i.e. when the new height first occurs. Most tweak settings of the TweakAtZ do for instance.
In general, a plugin can be triggered by nearly anything. It could be triggered after 1000s or as soon as the set temperatur is above 220°C... depending on its code...
jweaver 2
I have been doing some tests and the whole thing is very inconsistent.
I took a part which has 2 obvious layers as a base.. And I sliced at 0.2mm.
I set the plugin to 0.4mm assuming that it would stop AFTER the first layer.. But it stopped after the first.
So to get it to stop at the correct layer I had to choose 0.6 which is the 3rd layer.
But when I tested before it wasn't like this and using the layer view to predict the behavour is impossible.. Does anyone have any tips?
Jon
