Calibrate dual extruder with heated bed
caddy-cool
Posted · Calibrate dual extruder with heated bed
Hi guys do you have any tips on calibrating the dual extruders to the heated bed? I assume you just do as the wiki says except you don't adjust the 4 corners you use the 3 adjusters?
It is being hampered by backlash in the z drive causing the bed to drop just beyond the limit switch. Anyone know how to remove the play in the Z axis?
