OK looks like the day of my life finally came, in which I am waiting for a pink unicorn. Thank you Ultimaker
I guess this won't be solved until Pink Unicorn...
Indeed, the problem is in the wxPython toolkit, which is at the code of the current Cura. One of the goals of the rewrite was to change the toolkit to QT, which does not have these kinds of odd issues.
amedee 348
In some cases on Mac you end up with an 'hidden dialog box' (It is behind the main Cura window, and the way WxWidget works on Mac you cannot see it nor select it)
When you are in this situation drop boxes aren't working anymore.
If you start shuffling your main Cura window around you might see it...
