Cura skips hole on first layer when slicing
duke2773
Posted · Cura skips hole on first layer when slicing
Hello,
I am pretty new to 3d printing still learning a lot.
I am trying to print a dial indicator holder that I found on thingiverse.
When cure slices the part it skips a hole on the first layer but it is there on the others.
I used Netfabb to repair part. and it does the same thing with the repaired file.
any suggestion?
    www.thingiverse.com/thing:230746
    Thank you for your reply. in the bottom layers it fills in the bore where the indicator goes. then it opens back up. when it goes back to doing the top layer it fills in the bore again.
