You'll have to get your answer from other posters, I'm still waiting for my kit to arrive. What advantages would you expect?
- 3 years later...
https://zortrax.com/3d-printing-in-mold-making/zortrax-3D-printing-in-modern-mold-making.pdf
This Z-ULTRAT is filament fit for molding. Can the UM print this stuff?
Found to more filaments, and wonder if anyone used these.
Can UM2 handle these filaments?
https://www.matterhackers.com/store/3d-printer-filament?t=Polycarbonate%20%28PC%29
https://www.matterhackers.com/store/3d-printer-filament?t=MOLDLAY
Did not try but the mold lay should be ok looking at the temp. Just check if the 3mm is 2.85 irl.
For the PC or PC ABS you should probaly best convert the ultimaker to a full metal head like e3d-v6. And change the firmware to alow higher temperatures. Also you need to enclose the machine to create a heat chamber.
Edited by GuestDim3nsioneer 557
These filaments might print well with the TF2K coupler (TFT+I2K) from 3dSolex which allows for extrusion temperatures up to 300°C... ;)The standard hotend is capped at 260°C afaik.
Edited by GuestYeah the tf2k might be a good idea. Have not tested it jet myself at hight temps. Also in this case you need to change the max temp in firmware. For the normal hotend 260 is possible but will damage your ptfe faster.
Yeah standard head is capped at 260 but will only last a short time at that unless the mods are installed like Dim3nsioneer mentions.
remco 0
Can you melt it in an extruderhead? Does it come on coils? What is the meltingpoint?
