Bug when changing material in version 15.01; X or Y switch stuck
mcmarkus
Posted · Bug when changing material in version 15.01; X or Y switch stuck
I've found this issue on my UM2 with 15.01
- select Material->Change (wait to complete the procedure)
- press the knob on Ready for microstepping in
- press the knob Ready again to quick load the material
- press the knob again to be Ready as the material comes out
- now select type of material (example PLA), and OK
- the head homes
- now select Change again (the stepper makes a quick unload)
- the head homes and happens an error:
ERROR STOPPED
X or Y switch stuck
contact ultimaker.com
Let me know if somebody else has the same issue,
thank you,
Marco.
