tinkergnome 918
The issue is that once the material has been changed, it retracts a bit when you choose the type.
AFAIK the "standard" change material wizard is used during the pause. It retracts the loaded filament 20mm (the same value as the "end-of-print-retraction").
The "pause at height" plugin has an option "Retraction amount". Just increase this value for your needs and it should work.
For UltiGCode-Flavor this is a volumetric value (IMHO) - so you can use a value of approx. 130 (mm3) for 2.85mm filament.
I think there is an additional "normal" retract too (4.5mm? - done by the plugin) - so eventually you have to increase the value even a bit further.
reibuehl 40
Strange, I saw exactly the opposite behavior: After pressing resume, the nozzle went back to the place it stopped and then extruded a lot of material like it does normally in the front left corner before starting a print but this time on the printed object. Luckily I used little infill, so all of it just sunk into the infill.
