Ok, il try to get the tube and the connector. So far I can't find the tube anywhere :cry: . Also, when I opened the feeder I saw the white piece of plastic that rubs against the plastic, will making it wider help? ( so it can have more pressure on the thinner filament)
I've seen some great results with 1.75mm filament (with a different hotend), too bad it's about twice as expensive as 3mm filament.
That might depend upon region. I pay the same for PLA or ABS, 3mm or 1.75mm, its $33 cdn/kg.
I can't find the thinner bowden tube anywhere :( if anyone sees one please tell me.
Daid 304
The Ultimaker is not designed for 1.75mm filament. But with a thinner bowden tube and a different quick connect you might get away with it.
