But if you want to change the print speed go advanced and fine tune each speed (infill, outlines, etc)
Dim3nsioneer 556
You still can use TweakAtZ for that purpose (since V4.0).
yellowshark 153
If it is really important for you at various times then Slic3r lets you set the various speeds as %s of the prime print speed. You just need to then reduce the prime print speed by 20% or whatever and they will all reduce by 20%
really? I must update right now! Ty
Dim3nsioneer 556
Just use Cura 15.02.1...
neotko 1,417
The z plugin. You can change speed at any layer/mm and many more. It's a very very usefull plugin
