Firmware lockup 15.02.1
min0me
Posted · Firmware lockup 15.02.1
Hello,
I am unsure if this is the correct place to post about firmware, please move it if needs be.
I upgraded my ultimaker 2 shortly after the newest firmware was released and all was well, but in the last two or so weeks it has started to randomly lockup.
Either
It continues printing, but nothing changes on screen, if you use the scroll the wheel, it does not move between the options and it does not count down.
This can happen undisturbed or when tweaking settings
Or
It stops printing mid-way and just oozes, fans and heaters remain on and the screen garbles partially. It does not respond
This one happened about 10 mins ago
eg.
20150326 001
Both cases you have to switch it off and on again before it becomes responsive
I had reflashed the firmware twice from two different computers and I get the same problem.
It’s not all the time and can happen on quick prints or large prints.
I have an ultimaker 2
Debian 7/ Windows 7
Cura 15.02.1
Print from SD card
Both PLA/ABS
No mods
Card is also good and files end correctly
Thankx in advanced
    If you install the previous version of the firmware, will the printer behave or do you still have problems. I wonder if you may have some loose connections to the board, and this would be a way to test it, so that you are really sure you can blame it on the firmware.
    • 3 weeks later...
    So to update where I am.
    I downgraded the firmware to 14.12 (the previous one) which had worked well for me.
    The the hot end became blocked with the first print back at that firmware version and as I removed it to clean everything up (the atomic method didn't work) and I broke it.
    After much hunting I finally got a replacement hot end this morning and when I start my first print, the printer locks up, just like the picture above, reset it and calibrate everything again and right now its printing.
    • 2 weeks later...
    Ok, then I'd say it is a hardware problem. Either a connection problem like Personal Drones suggested (maybe a wire got loose somewhere) or the board just broke.
    You could take off the board cover at the bottom and inspect it for obvious problems.
        • 4 replies
