Hi John, in march 2016 I replaced the drivers for the X and Y-axis only, and got (and still have) a nice and quite UMO. So what you could do is set back the driver for the Z-axis (it doesn't make a lot of noise) and for the extruder.
Recently I replaced the extruder for a Bondtech one and finally got a reliable feed without underextrusion.
It's been a long time ago, but I do not recall the steps/mm had to be changed. Maybe I am wrong, but I would suggest to double check on that.
1
Top Posters In This Topic
41
20
13
8
Popular Days
Feb 18
11
Mar 6
10
Apr 14
8
May 22
8
ataraxis 41 posts
drayson 20 posts
tommyph1208 13 posts
mariuszem 8 posts
Popular Days
Feb 18 2016
Mar 6 2016
Apr 14 2015
May 22 2015
Popular Posts
halfie
Hi gr5, I picked up an ultiboard2 clone from aliexpress, named "v2.1.5" specifically to try out the TMC2100's. The board actually comes with individual micro jumper switches, much like the jumpers on
tommyph1208
Hands down, these stepper drivers are crazy! Printing 95 mm./s here: https://www.dropbox.com/s/fgqsl64ld2rtpr7/2015-04-14%2019.06.25.mov?dl=0 I had already done the "remove two pins and solder over
maartenw
Posted Images
JohnInOttawa 95
I know this is a very old topic - but I finally got around to installing these on my UMO (no heated bed). I think I have followed the instructions on this thread, and things are indeed quieter.
Because I had the time, I installed all 4 of them. X and Y are certainly quieter but with all sorts of layer shift starting at about layer 3, Z is quieter but for some reason Z no longer homes correctly and the extruder is underextruding and eventually not extruding at all.
I tried with the Vref all the way down at 0.8, got the layer shifting right there, and have been increasing it slowly, really not seeing any improvement, now at 1.1. I assume I am shortly (if not already), going to experience overvoltage heat issues. I also note that the shift follows a rapid move and Trinamic has a video recommending reduced acceleration rates. Could this be a fix and, if so, how far do I need to cut back on acceleration from default settings?
The extruder is a whole other thing. The retractions sound awful and then eventually stop. I am reducing voltage, will continue to do so, but the next step will be to revert back to the old driver. The noise was not that great to begin with and it's that I am targetting.
Z axis - the previous owner may have changed the lead screw (unable to verify), so I am wondering if my steps are wrong. In any event, the previous driver and steps at 533.3 homed correctly. Now, with 1066.6, homing causes the build plate to rise, hit the limit, back off, then rise and hit the limit again. I would have thought that homing would have an offset from the point the limit is reached, so I am wondering if there is a discrepancy between where the machine thinks that bed is and where it is in reality.
I guess I may be into a process to measure the correct steps/mm on Z.
As my primary is a UM3 and is happily ticking along, getting the UMO back is more of a wish than a need. These are authentic chips bought from a reputable source, so I am pretty sure it's something I'm doing wrong.
Any and all advice gratefully accepted.
Thanks!
John
