I am regularly using ABS and have found the following to be very reliable:
Have a clean glass bed and cover with a wash of ABS (the same colour as you intend to print with) dissolved in acetate. This holds the print well and has the added advantage of giving a great smooth bottom to the finished part. Once the print is finished let it cool slowly (which also helps reduce distortion) and you will hear it pop off the glass so it is easy to remove once cooled down.
I have a door covering the printers front and box mounted on top. The box has an open bottom for the Bowden tube and cables to enter, but this is not a problem as long as the room the printer is in has no drafts such as open windows. I was initially worried about the box over heating the printers drives etc but monitoring with a laser thermometer showed it to get to about 55 / 60 deg C on the motors. I have been doing this for a while and they seem fine.
My standard settings are:
layer 0.06 to 0.10mm
shell 1.20mm
retraction Y - "No skin" setting
Bottom / top 1.20mm (to match shell and I need quite robust parts)
fill 25%
speed 50mm/sec - but also see below speeds which seems to over ride this
Bed adhesion brim + wash as above
nozzle 0.4mm
initial layer 0.3mm
travel speed150mm/sec
bottom speed 20mm/sec
infill speed 50mm/sec
top/bottom speed 30mm/sec
outer shell speed30mm/sec
inner shell speed 50mm/sec
min layer time 5sec
NO FANS at any time
Bed temp 100 deg C
Nozzle temp 250 deg C
These speeds and layer heights can make for some slow prints, but I need the quality. I am sure you could speed them up a little if not needing high quality.
Hope this helps in at least giving you a starting point.
tsagos 8
Hello
Give us some details about temps, speed, layers etc. Temp is related with the grinding you are getting. Bigger temp means easier flow so the feeder motor doesn't require so much force to push the fillament.
reibuehl 40
I used to have similar problems in the past and the best method to prevent it for me was to add a door to the UM2 and heat up the room to at least 30°C. In the future I will try to cover the top too to avoid the room heating.
