Firstly it wont be 50micron in diameter. it more like a flat line. the width defined by the nozzle width which is normally 0.4mm (can vary a little) and the height is defined by our layer height. in your case 0.4mm wide and 0.05mm high.
I am currently printing at 20 micron layer height. I do a few prints at this but its not very common for people to go that low and depending on your model, most of the time it doesn't give the best quality.
you can get a aftermarket nozzle of 0.25mm which will mean your lines will be 0.25mm wide.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Labern 774
