Sounds like you have two problems we need to sort out:
1) Extruder motor does not work during the 'build' process.
2) Extruder motor does not work in manual control mode.
Problem 1)
It's hard to track down the problem based on the opening post. Answering Daid's questions will help to get to a solution.
Problem 2)
There are some known issues in Manual control mode in RepG with the extruder motor. Responsiveness of the extruder's buttons is really bad for some reason. The extruder motor should work just fine in 'build mode' though. Your non-running motor may be related to problem 1 but it might as well be this known issue...
M
Daid 304
Important first questions:
Did you change the firmware? (Else you are on 5D stock firmware)
Which version of RepG did you use?
Can you post the generated GCode somewhere? (
http://pastebin.com/
for example)
