In Cura: Load settings from gcode in the File Menu
sorry in cura I found only "load profile"
I tried to use it
and I got this message
"No profile found in Gcode file, This feature only works with GCode files made by Cura 12.07 or newer"
but I've Cura 15.02.1
DidierKlein 729
SandervG 1,519
Hi @afranx, thank you for your post.
Didier gave you a great way to retrieve the settings from your print.
From your SD card you can load your file back up in Cura.
Nonetheless, it is also valuable to get familiar with the structure of a gcode.
Sometimes you can do great things by manually tweaking the gcode.
For example this story could be interesting to read.
If you have found Didier's answer the right answer to your question, please go ahead to select it as 'Best Answer'. It will help future readers to find the best answer faster. Thank you!
Edited by GuestLink to post
