Thank you...
why far future ?
Where is the problem for modify this ?
This is important function for NORMAL works.
Who are the engine cura programmers ?
I think is very simple routine for integration in cura
This is only a: "IF extrusion.level (n+1)=true then not retract"
Dim3nsioneer 559
Hi Raffaele
Welcome to the UM forum.
Your idea is good. Many users thought about it in the past including me. The idea is actually to identify if a certain travel move in combing mode is on top or gets overlapped by the next layer.
It would have to be realised in the Cura slicing engine, not in a (post-processing) plugin. AFAIK the CuraEngine works on a layer at a time and does not care about the layer above or below (@daid and @bagel-orb, please correct me if I'm wrong). So it might be something for the far future.
