UMO plus fan shroud and alternative feeder?
Posted · UMO plus fan shroud and alternative feeder?
hello while i am waiting for the correct steppermotors for my umo plus i have been reading up on diffrent problems and challenges.
soo i am looking for good fan shrouds for the umo plus
and is there a good alternativ feeder for umo plus?
something like IRobertI's feeder for the umo plus?
just love the that it is soo simple and user friendly vs original feeder for the umo plus.
    To use that feeder on umo+ you need a different stepper motor with 400steps and 0.8 angle. The same that um2 uses. For fans depends if you want to keep the aluminium or change it all. There are plenty options on youmagine
    • 3 weeks later...
    look for "H3 Extruder", which is actually a feeder, on thingiverse (I don't know if it is on youmagine too). This one works really perfect.
    For the fan shroud there are many alternatives, but the original is really ok. There is a printable version on youmagine, which is more rigid.
    • 5 months later...
    thank you all for answering me and sorry for soo late respons :(
    been sick and moving :S
    now that the printer is up and running again i am having problem that prints on the side the fan dont blow on gets messed up and kind of leaks out :(
    so if any have a link to a fan shroud that is good and tried or a dual fan shroud plz tell me
    and i will check out the h3 extruder :)
