CPE
rigs
I have just noticed this new filament that popped up on the website. I'm wondering if it's a remodelled PET that came and went from the store a while ago. It comes with a PTFE insulator and says higher printing Temps.
    • 4 weeks later...
    I got this info from Ultimaker support:
    Printing with CPE has its pro's and con's, please see below:
    Con's:
    You need to print CPE on higher temperatures just like ABS. (240/250)
    Printing on higher temperatures will cause the PTFE to wear out faster and that is why we included one when you purchase a spool of CPE.
    CPE has just like ABS the tendency to warp, a heated camber may help reduce this.
    Pro's:
    CPE is just as strong as ABS.
    It does not have any dangerous fumes or strange odeur.
    It has nice bright colors.
    • Like 2
    Con's:
    Pro's:
    Ok many thanks ;)
    but questions remain...
    - TG ?
    - Strength to chemicals ?
    - optimal print setting ?
    Con's:
    Pro's:
    Ok many thanks ;)
    - TG ?
    Have no idea. I'm an amateur in this game, so I'm starting to think this spool won't the first I try out right now...
    Con's:
    Pro's:
    Ok many thanks ;)
    - TG ?
    hello,
    I can not to have good results with températurre between 240/250 °
    the best settings on my OU are
    Layer thickness: 0.04 mm
    Print speed: 40mm / s
    t ° nozzle: 223 °
    t ° carpets: 60
    flow rates: 110%
    What's an "OU"? Original Ultimaker?
    hello,
    t ° nozzle: 223 °
    t ° carpets: 60
    flow rates: 110%
    Have you tried putting heat bead to 80°C and flow to 100% with higher temperatures? Can you share images with your print?
    Posted (edited) · CPE
    here is a quad frame CPE
        • 6 replies
