A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
xeno 108
This could be several problems,
is the nozzle diameter set correct, or the feedrate.
the feeder screw can be changed, but too tight will deform the filemant, and could need more force to push through the bowden tube,
too lose and it will loose grip.
check the hobbelt bolt if it is clean, try to make a pic what the filament looks like after it is pushed through the feedr (teeth marks)
and if you are not sure if your Cura settings are correct, you can do a reset of all settings.
