Ahhrg.... just there was still what.Man because I otherwise always remember thought and this time totally overlooked.
I will probably slow blind with age.
Thanks Daid for your fast and Quick answer.
I use Arduino 1.0.1 as gcc i think it is up to date , or isn´it? (Date 21.05.2012)
Or does you use an other gcc?
Daid 304
Also those warnings are a bug in gcc, and workarounds applied caused other problems. The real solution is to upgrade your gcc version.
The most logical reason why your UltiController no longer works is because you did not enable it in the Configuration.h
