Fan percentage on Ulticontroller satus screen...
amedee
Posted (edited) · Fan percentage on Ulticontroller satus screen...
I see. Just in case @Amedee can do that and to make it faster for him:
The placeholder to rewrite it's on pins.h
//Motor current PWM conversion, PWM value = MotorCurrentSetting * 255 / range#define MOTOR_CURRENT_PWM_RANGE 2000#define DEFAULT_PWM_MOTOR_CURRENT  {1300, 1300, 1250}
Weird I only see this on the Motherboard 72 (Umo+/UM2) pin... So maybe someone else knows where to write
    Posted · Fan percentage on Ulticontroller satus screen...
    I can be wrong on this, but afaik on the UMO you cannot control it by software, it is a pot on the drivers...
    UMO+ has the Ultiboard 2 where it is possible.
    I'll look to add that on my next builder version....
    • Like 2
    Absolutely correct.
        • 7 replies
