Hi folks,
This may seem like a stupid question, but how do you change the time on the UM3E?
I've started pulling API data from the printer (http://xxx.xxx.xxx.xxx/api/v1/print_job) to monitor the status so I can plan when the next job can be put into the machine
The "datetime_started" is 1 hour out against local time (Edinburgh) I'm not sure if it's not updated to British Summer Time (I use the word Summer loosely ) or it syncs with a time server in Europe.
Something strange has now happened, the printer has been working fine with the updated time, however recently whenever the printer is powered down and back up the time resets to 01/01/1970?
I've went through the process of resetting the time / date and it works until the machine is power cycled:
https://www.garron.me/en/linux/set-time-date-timezone-ntp-linux-shell-gnome-command-line.html
Is there a version of a "BIOS" battery in the UM3 that could be flat?
