Hey Everyone, I am having an issue levelling with a new CC print core. No matter which slot I put it in I get "Difference between detected height of both print cores exceeds realistic values". I believe it to be defective. I do have the 7.1.3.0 firmware installed and do not have this issue with my AA and BB print cores in either slot. It will stop levelling before coming close to the bed. I know the sensor boards are sensitive so maybe something defective is throwing it off.
Most/many forms of carbon, including carbon fiber, are not conductive. Did you check it with an ohm-meter? It's true that nanotubes are conductive, but carbon fiber should not be.
I recommend you watch the leveling procedure - just the first two tests which are different. There are 3 failure modes:
1) Surface detected too early. As it does the leveling it never even touches the glass. This indicates electrical problem such as nearby interference.
2) Surface dete
