I'm trying to design models as "vase mode". I model in Fusion360 and my latest endeavor is that a few projects require single wall prints.
FIRST. I started off with a .41mm offset, (creating thickness of .41mm because a .4mm thickness will not slice)
So as a .41 thickness, the print head creates the full perimeter yet backtracks to the starting point. Its like watching an rotary phone! Print - rewind - print next layer.
After some troubleshooting, I found in the gco
